SpoonTorch v1.12[/b] (Freeware)
Requirements: PocketPC 2003(SE), WM5, WM6
Overview: Full screen torch application for your Windows Mobile.
Introduction
Does your phone or PDA not have an external light on it? Do you want to use your phone's screen as a light?
This app lets you quickly create a white screen to use as a torch.
Features
* Single tap of the screen to make the whole screen turn white. Tap again for the menu.
* Switching to fullscreen, backscreen brightness is set to maximum. Old settings are restored when fullscreen is exited.
* Minimise to program menu. So you can quickly switch between this and Windows Mobile itself, without closing the app.
Version History
v1.0 13/11/09 - Initial release
v1.1 14/11/09 - Backlight booster for fullscreen
v1.11 15/11/09 - Backlight maximum taken from registry
Backlight timeout disabled in fullscreen
(this setup file was incorrectly named v1.2)
v1.12 15/11/09 - Disable power save in fullscreen
Requirements
* Needs .NET Compact Framework 3.5+.
* Should work on all Windows Mobile devices.
* Non-touchscreen compatible (Windows Mobile Standard).
More Info
Introduction
Features
Version History
Requirements
More Info
http://forum.xda-developers.com/showthread.php?t=584056
http://www.megaupload.com/?d=ZZFX1B5M
