SK ScheMa v1217
    [RELEASE] SK ScheMa v1217
    SK ScheMa v.1.2.17
    Requirements: WM2003-6.5
    Overview: SKScheMa is a multi-functional scheduler allowing to automatically perform different actions at the time specified as well as to perform actions depending on other programs being launched/closed.
    The program can be used as an advanced alarm clock and also as a reminder.
    For example, the program makes it possible to set the following tasks:
    “to launch a backup program at 0.40 every Tuesday during January and February 2006”
    “to awake the owner daily during a week with different sound files”
    “to establish a GPRS connection if a mail client or PocketIE is launched”…
    Watch for some phone events like rings, answer, hangup, power state, SMS.
    SKScheMa can run command/script/program for all this events
    SKScheMa features:
    # runs programs, plays sound files at the specific time, with the specified periodicity
    # shows a reminder at the time specified along with a signal (a sound file, vibro). A reminder can be postponed.
    # sends SMS at the time specified
    # makes a phone call at the time specified (it is very useful when somebody should be woken up automatically)
    # switched PDA on and off and makes a soft reset at the time specified
    # closes the indicated programs at the time specified
    # clones an event (for example, to beep every 25 min within 5 hrs)
    # change today theme at the time specified
    # switches a phone on and off (PIN-code input is possible), BT and Wi-Fi on/off
    # emulates a screen tap or a keyboard input
    # supports scripts which are to be executed at the time specified as well as directly from Explorer or with a shortcut in Start Menu
    # watches launched and closed programs (by window name) and performs different actions for these events
    # watch phone events
    # watch new messages
    # watch storage card (if inserted/removed)
    # watch power and battery state
    # watch for registry (WM5+)
    # has an adjustable Today plug-in showing the most immediate tasks and also used for a quick-launch of SKScheMa
    # it is possible to create frequently used sets of events
    # FreeUP RAM Service New!
    # many other features
    # QVGA, VGA support
    # WM2003(SE) WM5 Pocket PC (Phone Edition), WM6 WM6.1 WM6.5 Classic and Professional compatible
    Options for event scheduling in SKScheMa:
    1. The simplest option the time is specified. The event will occur daily at this time. This is a setting by default.
    2. The same as (1), but the event will occur only once.
    3. Launch on certain days of a week.
    4. Launch on certain days of a month.
    5. Indication of certain month and year.
    6. Launch on he Nth day of the current/specified month (e. g. every third Tuesday of March, April and July).
    7. As an extra, via ‘Sequence script’ it is possible to specify a sequence of runs (e. g. 3 scheduled runs are performed, the next one is skipped).
    New features
    * watch for registry (WM5+)
    * UI improved for finger
    * user can call owner information dialog from About tab
    * arrays support in script
    * new commands #setitem, #getitemsnum, #removeallitems, #regmathall, #file2array, #readfromfile, #setprofile, #ping
    * compression support for #wrecord
    More Info
    http://s-k-tools.com/index.html?skschema/m_skschema.html
    use keygen
    SK ScheMa v.1.2.17
    http://depositfiles.com/files/od6ogrkun
