Project Name: WAR
Device: RhodiumW
System: Windows Phone 21887
Interface: HTC Sense 2.5 [FULL LANDSCAPE SUPPORT]
Date Built: 12/30/09
Download: Click Here
Project Name: LOVE
Device: RhodiumW
System: Windows Phone 28014
Interface: HTC Sense 2.1
Date Built: 12/27/09
Project Name: IMPACT
Device: RhodiumW
Date Built: 12/28/09
Project Name: VOID
Device: RhodiumW
Interface: Titanium
In Light of the newest builds with landscape :) The blue theme will be getting a makeover this week and will be temporarily disabled.!
Thank you for your patience!
MightyROM 6.5.3 & Sense UI 2.5
A Detailed FAQ
A Detailed FAQ
Last Updated 12/30/09!
The purpose of this post is to allow those new to either MightyROM or the new SenseUI for this edition (known as Manila 2.5) to get a better understanding and have any questions. BE SURE TO READ THIS REGULARLY. If anything develops for this ROM, such as a specific CAB to fix or customize a feature, or perhaps a new way to do something, it will be here!
Important Touch Pro2 Links!
CDMA Rhodium HSPL (Thanks to Cmonex and the Elite Team!)CDMA Rhodium Radios (Thanks Juggalo_X!) Touch Pro2 FAQ (By Laos101)
CABS & LINKS
See a full list of cabs i put in my user file HERE!
THE MIGHTYROM ESSENTIALS
It is HIGHLY SUGGESTED You download all of the below CABS for a better experience of the MightyROM.
Adudiopara - Increase your speakphone volume
Battery Monitor - Keep in touch with your battery usage!
HD Tweak - plenty of tweaking
Groveshark - Music! NEVER leave home without it!
psshutXP - Great alternative to the standard power off screen
RamSweep - [i]Sweep your RAM (THANKS TO CODYBEAR FOR INCLUDING THE BT STACK FIX IN CAB)
Registry Editor - Must I say more?
File Explorer Extender - Get more for File Explorer
Total Commander - File Exploring
TP2 Battery - Get % specifics when using your tp2!
IE Toggle - Toggle between IE6 and PIE so you can use LogMeIn
kbdcontrol - manipulate your keys and do more.
THE MIGHTYROM SUGGESTED
These make the experience better, and are suggested, but not absolutely necessary.
MaxManila - enhances 2.5 Manila!
MyStopWatch - A cool app to measure time
TOUCHPRO MEGA ARCADE - Cool Arcade Kit, even if most of it is VGA, its still a cool arsenal against boredom
Google Translator - a quick and easy app to translate while mobile.
Tsowen Taskbar - 6.5 compatible GFXs! MIGHTYROM "WAR" ONLY
6.5.X Taskbar - MIGHTYROM LOVE OR IMPACT
Skype - Another "Never leave home" app
SENSEUI QUESTIONS
What is War? What is Love? What is Impact?
What is Love? Baby don't hurt me.. No more...
On a serious note, to appease the masses, MighyMike has decided to release two major editions of his 6.5 ROM for the Touch Pro2. One is called Project WAR, and the other is known as Project LOVE.
The biggest difference between the two is that Project WAR will include Manila 2.5 (AKA HTC Sense for HD2/Leo) which includes the enhanced version of TF3D, while LOVE will include Windows Mobile 6.5.3, which includes the start menu at the BOTTOM, an enhanced UI, and other unsupported features
Please note NEITHER of these ROMS are offered support by MightyMike, though he takes great skill and care into cooking them, they are served as-is with a waiver at the door! Choose them and try the unstability if you dare
MightyROM's PROJECT IMPACT project is a joint combination of 6.5.x and HTC Sense UI 2.5. As a result, it is also the most unstable of his releases, this one is very similar to that of the "Energy" ROM testbed with 6.5.3
What is SenseUI?
Manila, or Touch FLO3D, or HTC SenseUI, is a series of today screen replacements released by the creator of the Touch Pro2, HTC. However, the Touch Pro2 features Manila 2.1, a advanced and commonly seen version of the replacement. It features a lot of standard features and is on the other TP2 MightyROM edition, and stock devices.
The new one, extracted from the HTC Leo (Another HTC WVGA device) and is intended to replace the 2.1 version. The problem however is that the Leo has twice the MHZ and an extra 128MB of RAM! As a result, there are some problems with SenseUI.
What kind of problems are within The SenseUI?
EDITED. The latest MightyROM build NO LONGER needs the Landscape fix. To add, it is CDMA default compatible with landscape. Please enjoy, as now there are no longer any issues with landscape on the sense UI!
http://forum.xda-developers.com/showthread.php?t=588476
I don't like the weather animations! How do I turn them off?
Just go into your registry and make this edit.
[HKEY_CURRENT_USER\Software\HTC\Manila]
"Home.WallpaperMode"=dword:00000002
Note: changing your wallpaper will reset this.
MMS?
If you want to run MMS, SEE POST #5
Can I add this to Manila? Can I remove this from Manila?
Probably not. Manila 2.5 is very delicate. As a result, a lot of modifications are impossible due to restrictions of the manila. For example, one cannot add a certain tab to one manila, and perhaps remove a certain feature to another. As a result you can try to edit your manila files at your own risk, but be warned it probably will not work
WINDOWS MOBILE 6.5.3 QUESTIONS
Why the new look?
The new graphical design for 6.5.3 is revolutionary for the device. it focuses on a more finger friendly environment, taking advantage of the extra space on the screen for WVGA devices. Though a little slowly, less compatible, and more buggy then past OSes released by MightyMike, it is his attempt to offer you the 6.5.3 series from him in direct.
OTHER QUESTIONS
Why MightyROM?
Specifically. It depends on what you want. If you want a ROM that has every single feature imaginable combined into a single package, then you should consider EnergyROM. If you want a pretty stable ROM, try Juicy, but based on experience, MightyROM takes the cake. It does 2.5, it does it less buggy than the other releases out there, and most importantly, it uses less memory and processing power. I'd average 60% on a Juicy R6 ROM, but MightyROM WAR uses just 40%.
Why Bother?
Although Mighty Mike made these ROMS out of a mixture of popular demand and such, he also made them for his personal experimentation. It is backwardly for a developer to refuse on investing time to experiment with the up and coming new software to use on the devices. Over time, this day had to come. Mike is just shelling out the ROMS now, trying to learn about the ROM and find out its pros and cons. Who knows, perhaps he, along with the other experimental developers, could find an interesting bug or fix that could help us revolutionize into a new age of 6.5.5 and 2.5 Manila ROMS with much better stability than now**Thanks to Ziggy and CuzinBucksBx**
CONFIRMED FOR VERIZON AND SPRINT!
*******THEY ARE ALL CASE SENSITIVE!!*******
MMS FIX FOR VERIZON, SPRINT AND US CELLULAR.
YOU DON'T HAVE TO DISABLE HTC MESSAGING
JUST GO TO MESSAGING TAB>ALL MESSAGES>MENU>SETTINGS>OPTIONS>MENU>MMS SERVER
THEN ENTER THIS DEPENDING ON YOUR CARRIER:
US Cellular
Server name: Your Choice
Ip Address: Blank
Port Number: 80
Server Address: http://mmsc1.uscc.com/mmsc/MMS?X-USC-MDN=your number here
Connect Via: Data or USC Or whatever your data connection is
Send Limit: 1024 KB
Verizon
Ip Address: Blank
Port Number: 80
Server Address: http://mms.vtext.com/servlets/mms?X-VZW-MDN=your number here
Connect Via: Data or #777 Or VZW or whatever your data connection is
Send Limit: 1024 KB
Sprint
To Get Your MSID Number Dial ##778
IP Address: Blank
Port Number: 80
Server Address: http://mms.sprintpcs.com/servlets/MMS?X-SPRINT-MDN="YOUR MSID NUMBER"
Connect Via: Whatever you data connection is
Send Limit: 1024 KB
NO WAP FOR ANY OF THESE
http://forum.ppcgeeks.com/showthread.php?t=101356
