[APP]SVMPowerMgr 20 Power comm utility
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    [FREEWARE] [APP]SVMPowerMgr 20 Power comm utility
    Hello.
    This is the "reloaded" of SVMPowerMgr 1.0.
    With this app. You can:
    - turn off the screen of Your device
    - put the device in suspended mode
    - soft reset the device
    - turn off the device (HTC devs.).
    - turn on/off wifi
    - turn on/off phone module
    - turn on/off bluetooth (make discoverable/invisible)
    - switch phone bands Auto-2G-3G
    You also can create 7 shortcuts to the program with parameters:
    0 - turn off the screen of Your device
    1 - put the device in suspended mode
    2 - soft reset the device
    3 - turn off the device.
    4 - turn on/off phone module
    5 - turn on/off wifi
    6 - turn on/off bluetooth
    somethig like this
    [simbols count]#"[path to program]SVM Power Mgr.exe" [parameter]?[path to icon file you want to use],-[icon index]
    You can change the images of backrounds button separator and buttons, they will be located in "Images" folder after install. With one restriction: now the buttons are black, so if you change the back of main program, consider this ...
    Remarks: To close the main window you must tap anywhere outside the buttons or in space between buttons. Also to close additional windows tap the Close button or empty space of window.
    P.S.
    Discoverable/invisible mode for bluetooth is working on Microsoft stacks, on broadcom is to be developped (works just on/off bluetooth)
    P.S.S.
    Supported screen resolutions: QVGA (240x320), Square (240x240), SquareQVGA (320x320), VGA(480x640), Square VGA (480x480), WVGA (480x800)
    No credit taken thanks to s.virtan over at XDA for this great app
    Original Link:
    http://forum.xda-developers.com/showthread.php?t=609343
