3GMobile SMS+Contacts Backup v2.08
Requirements: WM5-WM6.x
Overview: 3GMobile SMS+Contacts Backup is an app used to backup sms and contacts on windows mobile.
You could use this software to save your mobile outlook contacts and sms as .xml or txt file;Restore sms and outlook contacts from pc to mobile phone;Manage sms & outlook contacts on pc.
With 3GMobile SMS + Contacts Backup, you can:
* Backup SMS Messages for windows mobile into txt file or .xml backup file and save onto your computer
* Restore SMS Messages from a .xml backup file
* Support all SMS default folders (Inbox, Outbox, Drafts, Sent Items, Deleted Items) and custom folders.
* Export your outlook contacts into txt file or .xml backup file format and save onto your pc
* Edit outlook contacts info on computer directly
* Restore outlook contacts from the .xml backup file
* Support unlimited outlook contacts and SMS backup/restore.
* Fast backup and restore speed
* Fully Support Windows Mobile 5/6.0/6.1/6.5
* Easy to use
keygen
* Easy to use
http://www.3gmobiletool.com/
http://rapidshare.com/files/328754214/3GMobile.SMS.Contacts.Backup.v2.08.rar
http://netload.in/dateiF8PFF5jO4V.htm
