Lockbot Pro v1.9.3 updated 1.10.2010
  • Bigrob
    • 1107
    • Touch Pro
    [RELEASE] Lockbot Pro v1.9.3 updated 1.10.2010
    Requirements: Android
    Overview: LockBot is an iPhone or Hero-like lock screen editor
    You can customize your lock screen by
    -iPhone, Hero, Eclair style
    -Digital, Analog Clock
    -Flickr, Picasa, Wretch or Pics on your SDCard as background
    -Unlock sound
    -Download Theme(LockBot Pro Only)
    http://www.androlib.com/android.application.com-jackdoit-lockbot-xjti.aspx
    http://www.megaupload.com/?d=C07PS1A8
    or
    Use Rapidshare:
    http://rapidshare.com/files/329946870/LockbotPro_1.81.apk
    Re: Lockbot Pro v181
    this should be nice for the droid users as well as others.... have tested on buddies g-1 here at work right now and works great thus far... very quick install and does what it is supposed to do .
    • elboriyorker
      OG Member
      • Nov 08
      • 9328
      • Metro
      Re: Lockbot Pro v1.9 updated 1.8.2010
      post updated to v1.9
      SPJ Bulletin @
      www.smartphonejunkie.org
      • 1cooltreeguy
        Member
        • Jan 08
        • 87
        • mogul 6800
        this works pretty good but the one problem I have is that any button pushed can cause the phone to turn on...this causes the phone to stay awake with the screen on while in a holster. I don't know if the new one addresses the issue. good find though
        • elboriyorker
          OG Member
          • Nov 08
          • 9328
          • Metro
          updated to v 1.9.2 that should fix whatever issue you had
          SPJ Bulletin @
          • elboriyorker
            OG Member
            • Nov 08
            • 9328
            • Metro
            Re: Lockbot Pro v1.9.3 updated 1.10.2010
            post updated to 1.9.3
            SPJ Bulletin @
