VulumeX v 126
    [RELEASE] VulumeX v 126
    Volumex is an extension/replacement for the tiny Windows Mobile volume control and for other volume controls as well. Yet better, Volumex will make your volume management experience the best and easiest ever! Not only by being larger but by adding extra useful features.
    Have you ever went out from the movies and forgot to un-mute your phone? Or have you ever forgot to mute your phone during a meeting? Probably yes, but with Volumex this wont happen anymore!
    Features overview
    * Set your default(standard) volume.
    * Volume quick timer to auto revert to your default volume.
    * Volume reminders, so you never forget to revert your default volume back.
    * Auto silence/vibrate/maxvol when a specific appointment starts, and auto revert when ended.
    * Auto mute all system sounds during phone calls.
    * 100% finger friendly.
    * Direct accesibility to both system and phone volume rockers on the same screen.
    * Haptic feedback when changing volume.
    * No more "tick" sound when changing volume.
    * Option to lock volume silders so you can change them together.
    * Volume level preview.
    * Change in-call volume supported.
    * Headset/bluetooth indicator.
    * Skins/themes support.
    * Windows Mobile 6.0, 6.1 and 6.5.
    * VGA, QVGA, WVGA, WQVGA supported.
    http://volumex.jdbp.mobi/download.aspx
