CrazySoft Aristotle Virtuousness Test v1.4
From the makers of the best seller 'Personality Psychology Pro' another interesting title about ethics and virtues called 'Aristotle Virtuousness Test'.
From the makers of the best seller ‘Personality Psychology Pro’
another interesting title about ethics and virtues called ‘Aristotle Virtuousness Test’.
This program is a simple 11 step test which determines how much virtuous you are
according to Aristotle*. (*It's the world known Ancient Greek Philosopher, Plato's student.)
This test should be done by someone who knows you very well. (E.g.: Family, partner, friend...)
Don’t do it yourself! After the test you will be given a score out of 100.
Then you will be given detailed stats of what should be done to correct
your flaws according to Aristotle.
VIRTUES ARISTOTLE FOUND:
1) Courage
2) Temperance
3) Liberality
4) Magnificence
5) Pride
6) Honour
7) Good Temper
8) Friendliness
9) Truthfulness
10) Wit
11) Friendship
12) Justice (Not used in the test)
Every word used in the test is explained by Aristotle’s original text
(Translated into English) E.g. here Aristotle explains Courage:
“Aristotle: (Nicomachean Ethics, 330 BC) VIRTUE: COURAGE
The man who exceeds in fear is a coward; for he fears both what he ought not and as he ought not,
and all the similar characterizations attach to him. He is lacking also in confidence;
but he is more conspicuous for his excess of fear in painful situations. The coward, then,
is a despairing sort of person; for he fears everything. The brave man, on the other hand,
has the opposite disposition; for confidence is the mark of a hopeful disposition...â€ÂÂ
---22/Sep/2009 UPDATE (1.4) ---
* Alerts during gameplay bug fixed.
* Windows Mobile 6.5 full support.
* New hi-resolution icon in WM 6.5.
* Screen Rotation errors fixed.
* Minor bugs fixed.
RESOLUTIONS: QVGA 240x320 & 240x400,Square 240x240, 320x320,VGA 480x640 & 480x800,Square VGA 480x480.
1) Courage
2) Temperance
3) Liberality
4) Magnificence
5) Pride
6) Honour
7) Good Temper
8) Friendliness
9) Truthfulness
10) Wit
11) Friendship
* Minor bugs fixed.
http://rapidshare.com/files/332737903/CrazySoft.Aristotle.Virtuousness.Test.v1.4.Retail-ShareFreePDA.zip
http://rapidshare.com/files/332737106/CrazySoft.Aristotle.Virtuousness.Test.v1.4.Retail-ShareFreePDA.CAB
http://depositfiles.com/en/files/m9lg84fds
