Instructions:
1. Install the i860 R1.02.01 upgrade utility 38MB
2. Install the patcher 290KB
3. Run the upgrade utility on your phone (takes 30-45 minutes)
4. Enjoy your new phone
This only been tested this on phones with R1C.02.01 pretty sure you can downgrade .Instruction will be posted on how to
If you want to revert back to the original theme just reinstall the upgrade until and re-flash your phone.
How to downgrade from 03 to 01:
1. You will need the 03 and 01 upgrade until.
2. Install the i860 R1.02.01 upgrade utility 38MB
3. Install the i860 R1.02.03 upgrade utility 111MB
4. Install the patcher 290KB
5. Open this folder and delete EVERYTHING in it:
C:\Program Files\Motorola\iDENi860R1C0203UpgradeUtility\i860
6. Open this folder and copy EVERYTHING to the first folder:
C:\Program Files\Motorola\iDENi860R1C0201UpgradeUtility\i860
7. Run the 03 upgrade until on your phone
8. Enjoy your awesome new theme
Just remember, there is always the possibility of screwing up your phone. Do so at your own risk.
Ptech at no-way take credit for this ,this is for educational purposes only
