Kuo: iPhone 16 Pro Max to bring higher-density battery
    • 17983
    We recently saw some comparison images between the iPhone 15 Pro Max and the upcoming 16 Pro Max showcasing their size differences. Now, analyst Ming-Chi Kuo is reporting on the battery of the next-generation Pro Max iPhone, claiming it will feature a higher energy density.
    iPhone 16 Pro Max vs. 15 Pro Max
    According to Kuo, the iPhone 16 Pro Max’s higher-density battery will offer longer battery endurance in the same form factor as the current battery cell used in the 15 Pro Max. The higher-density battery will emit more heat which is why Apple is rumored to use a stainless...
    Read More From Source
