Best Power Bank in 2025: Top Picks for Travel, Laptops, and Fast Charging
    Looking for the best power bank in 2025? Whether you’re charging a smartphone, tablet, laptop, or wireless earbuds, today’s power banks are faster, smarter, and more versatile than ever. With USB-C PD, high-wattage outputs, and even MagSafe compatibility, the right portable charger can keep your devices powered up at home, in transit, or on the go.
    In this guide, we’ve handpicked five of the best options across different categories, from high-capacity laptop chargers to slim travel-friendly designs. Whether you need fast charging for your iPhone or a 140W powerhouse for your MacBook, there’s a power bank here that fits your needs and budget.
    Quick Overview: Best Power Bank for 2025
    Editor's Choice
    Best Wireless Charging
    Best Budget
    Best for Laptops
    Best Aesthetics
    Nitecore NB10000 Gen III (Gen 3)
    Anker MagGo Power Bank
    OKZU 10000
    Anker Laptop Power Bank
    SHARGEEK 170 Power Bank
    $64.95
    $89.99
    $22.99
    $119.99
    $169.00
    Buy Now
    Buy Now
    Buy Now
    Buy Now
    Buy Now
    Editor's Choice
    $64.95
    Buy Now
    $89.99
    Buy Now
    Best Budget
    OKZU 10000
    $22.99
    Buy Now
    Best for Laptops
    $119.99
    Buy Now
    Best Aesthetics
    $169.00
    Buy Now
    Editor’s Choice
    Capacity: 10,000mAh | Weight: 5.3 oz | Ports: 1x USB-C | Water Resistance: IPX5 | Charging Time: 4 hours
    If you’re looking for the best power bank that balances weight, durability, and charging performance, the Nitecore NB10000 Gen 3 is hard to beat. Weighing just 5.3 ounces, it’s one of the lightest and most compact 10,000mAh power banks on the market, making it an ideal companion for backpackers, digital nomads, or anyone who travels light. Despite its small footprint, it delivers solid performance with quick charging and pass-through capabilities, and it even supports trickle charging for smaller devices like smartwatches or earbuds.
    What makes the NB10000 Gen 3 stand out is its power-to-weight efficiency. In independent tests, it delivered more usable energy per ounce than any other power bank in its class. The carbon fiber frame and new rubber-corner design give it better drop protection and durability, while the IPX5 water resistance rating means it can handle light rain or spills with ease. It’s a minimalist device by design, with a single USB-C port and no USB-A, so you’ll need to make sure your cables are compatible.
    While the 4-hour recharge time is longer than some budget options, the trade-off is worthwhile if you value efficiency and packability. It’s a strong contender in the ultralight USB-C power bank category and perfect for those prioritizing weight savings and rugged design. Whether you need a fast-charging solution for hikes, flights, or daily commuting, the Nitecore NB10000 Gen 3 delivers serious power without the bulk.
    Nitecore NB10000 Gen III (Gen 3) Ultra-Slim Power Bank, 10000mAh QC...
    −$13.00
    $64.95
    🛜 Best For Wireless Charging
    Capacity: 10,000mAh | Output: 27W wired / 15W wireless | Charging Ports: 1x USB-C (MagSafe) | Weight: 8.8 oz
    If you’re hunting for the best power bank with wireless charging, the Anker MagGo is a premium option tailored for iPhone users. With full MagSafe compatibility and a strong magnetic hold, it attaches securely to your phone and delivers 15W wireless charging without needing a cable. A built-in flip-out stand makes it easy to prop your device up while it charges, and a digital display shows battery level and estimated charging time.
    Beyond wireless, this portable charger also supports fast USB-C charging at 27W for Android devices and can top up a Pixel or iPhone in just over an hour. It’s heavier and bulkier than standard models, but the extra build quality, display, and MagSafe support more than make up for it. For those prioritizing convenience and style, this is one of the best power bank options available in 2025.
    Anker MagGo Power Bank, Qi2 Certified 15W Ultra-Fast MagSafe-Compatible...
    $89.99
    OKZU 10000
    Best Budget
    Capacity: 10,000mAh | Output: 20W | Charging Ports: 1x USB-C, 1x Micro-USB | Weight: 6.6 oz
    The OKZU 10000 offers unbeatable value for those looking for the best power bank on a budget. With a fast recharge time of just over two and a half hours and support for USB-C fast charging at 20W, it punches well above its price. It’s also fairly light and compact, fitting into a large jacket pocket or backpack with ease.
    While it lacks high-end features like wireless charging or a digital display, it does support pass-through charging and can charge multiple devices at once. If you’re after a dependable USB-C power bank without breaking the bank, this is easily one of the best options under $30.
    OKZU 5V 2A Power Bank for Heated Vest, Jacket, Stadium Seats, Chair Battery...
    $22.99
    Best for Laptops
    Capacity: 25,000mAh | Output: 140W (100W per port) | Charging Ports: 3x USB-C, 1x USB-A (2 built-in cables) | Weight: 21 oz
    For power users and professionals, the Anker Laptop Power Bank stands out as one of the best power bank options for laptops and large devices. With up to 140W total output and three USB-C ports, it can fast charge a MacBook Pro, iPad, and phone at the same time. Built-in cables add convenience while reducing clutter, and the durable construction includes a handy display to monitor charging stats.
    Despite its heavy-duty capacity, it’s still compact enough to fit in a backpack and is airline-friendly. If you need a reliable USB-C laptop power bank that’s built to last and capable of charging multiple devices on the go, this is a top-tier choice.
    Anker Laptop Power Bank, 25,000mAh Portable Charger with Triple 100W USB-C...
    −$15.00
    $119.99
    Best Aesthetics
    Capacity: 24,000mAh | Output: 170W | Charging Ports: 2x USB-C, 1x USB-A | Weight: 24 oz
    If aesthetics matter just as much as performance, the SHARGEEK 170 is the best power bank for standing out. With a futuristic transparent design, vibrant internal LEDs, and a full digital display, it looks more like a gadget from a sci-fi movie than a power bank. But it’s not all show—this 170W monster delivers fast charging for everything from phones to laptops and even supports simultaneous multi-device charging.
    It’s a bit heavy for everyday carry, but the hardware is impressive. With 140W recharging speeds, IP66 water resistance, and a user-friendly display, it’s a feature-rich choice for those who want something different. If you’re searching for a high-capacity power bank that blends function with flair, this is a stylish and powerful alternative to more traditional options.
    SHARGEEK 170 Power Bank, 140W PD3.1 Portable Charger 24,000mAh/ 84.6Wh with...
    $169.00
    Can You Bring a Power Bank on a Plane?
    Yes, you can bring a power bank on a plane, but only in your carry-on baggage. Power banks are classified as lithium battery devices, and aviation regulations prohibit them from being stored in checked luggage due to fire risks. This rule applies across most major airlines globally, including the TSA in the United States.
    Most carriers follow Watt-hour (Wh) limits to determine whether a power bank is allowed:
    • Power banks under 100Wh are permitted in carry-ons with no limit on quantity.
    • Power banks between 100Wh and 160Wh are allowed, but only two per passenger, and you’ll need airline approval.
    • Power banks over 160Wh are completely banned from passenger aircraft.
    To check your power bank’s watt-hour rating, look for it printed on the label or calculate it using:
    Wh = (mAh ÷ 1000) × Voltage.
    However, not all countries follow the same rules. A recent policy shift by the Civil Aviation Administration of China (CAAC) now prohibits passengers from flying with non-certified power banks on domestic flights. As of June 28, 2025, power banks must carry the CCC (China Compulsory Certification) label to be allowed onboard. This change comes in response to a series of overheating incidents and mass recalls from major brands like Anker and Romoss, who were found using defective or unauthorized battery cells in over 1.2 million units.
    While most power banks under 100Wh are allowed on planes, always double-check local airline policies, especially when traveling in or through countries with stricter regulations like China. And for safety’s sake, avoid using damaged, off-brand, or uncertified models.
    The post Best Power Bank in 2025: Top Picks for Travel, Laptops, and Fast Charging appeared first on Phandroid.
