Long Flights? No Problem. Sennheiser Momentum 4 Wireless Drops to $279 (Save $170)
    • 18077
    Boarding a plane or train and realizing your headphones are dead is one of the most frustrating travel problems. But with a battery life of up to 60 hours, the Sennheiser Momentum 4 Wireless makes sure that never happens. You could fly from New York to Shanghai three times and still have power left to spare, even with noise cancellation turned on.
    Right now, the Momentum 4 Wireless is available for just $279.95 on Amazon, down from $449.95.
    Check the listing before the price jumps back up.
    Great Sound, Smarter Noise Cancellation
    These headphones are all about balance. The sound is clean and musical with a wide, natural soundstage that avoids the usual over-processed bass or shrill highs. Reviewers describe the experience as layered and spacious, with detail across the full range of frequencies.
    Noise cancelling is excellent too. An adaptive ANC mode automatically adjusts to your surroundings, whether you’re stuck in airport chaos or cruising on a quiet train. You can also use the Smart Control app to fine-tune your audio, create sound zones, and adjust ANC and EQ settings based on location.
    The Momentum 4 competes with the Sony WH-1000XM6 and Bose QC Ultra, both of which are also great for travel. But those models typically cost around $200 more than this current deal.
    While Sony may still have a slight edge in sonic detail, Sennheiser doubles its battery life. That makes a huge difference if you want headphones that can handle multi-day trips without reaching for a charger.
    Grab it now for $279 on Amazon before this rare discount ends.
    Travel-Friendly and Comfortable
    The ear cups swivel flat, so they pack easily into a backpack or carry-on. While they don’t fold completely, they’re light and soft enough to wear for hours without pressure or ear fatigue. Whether you’re watching movies, taking calls, or just shutting out the world, these won’t weigh you down.
    You also get support for multipoint Bluetooth, aptX Adaptive, transparency mode, and even wired playback if needed. That flexibility makes them one of the most complete travel headphones on the market right now.
    If you want long battery life, reliable ANC, and comfortable wear without shelling out premium dollars, the Sennheiser Momentum 4 Wireless is the one to get. It’s a true travel companion and one of the best-value headphones you can buy today.
    href="https://www.amazon.com/dp/B0B6GHW1SX?tag=phndrd-20&linkCode=ogi&th=1&psc=1" title="Sennheiser MOMENTUM 4 Wireless Headphones - Bluetooth Headset for..." rel="nofollow noopener sponsored" target="_blank">
    • Firmware and software updated: Enjoy a smoother, and more reliable user experience, incl. an ANC off switch in the Smart...
    • Maximum audio resolution with Sennheiser Signature Sound: Enjoy premium music quality all-day long thanks to the headphone's...
    −$170.00
    $279.95
    The post Long Flights? No Problem. Sennheiser Momentum 4 Wireless Drops to $279 (Save $170) appeared first on Phandroid.
