https://www.youtube.com/watch?v=QKTktqJHV1s
Now that the Google Pixel 10 launch is over, it’s time to look to the next huge smartphone launch of the year: the Apple iPhone 17 series. Although we don’t know exactly when they will land, Apple traditionally launches them in the second week of September, so it’s not far off yet.
Ahead of time, though, Android Authority has obtained a leaked Thinborne case based on the iPhone 17 Pro Max design. This case lines up with leaks we’ve already seen for what the iPhone 17 series should look like. Curious, we put the iPhone 17 Pro Max case on its most current generation sibling, the iPhone 16 Pro Max. Check out what we found in the images below.
- Android Authority obtained a leaked iPhone 17 Pro Max case from a company called Thinborne.
- The case fits very well on the iPhone 16 Pro Max, showing that the sizing is nearly identical.
- However, Apple appears to be moving the LiDAR sensor, microphone, and flash, so iPhone 16/17 cases will likely not be interchangeable.
