Solar Powered Charging Solution
  • VenumX
    The VenumX Factor
    • Nov 14
    • 1410
    • HTC Touch PRO
    Just came accross this Solar Powered USB hub that allows you to charge off of it, check it out:
    Here are the features:
    - As a charger to your mobilephones (see note below)
    - It is a Hybrid Charger (rechargeable by Solar panel and USB Port)
    - It is 4-port USB 2.0 Hub (backward compliant to USB 1.1, USB 1.0)
    - The solar panel can charge this device even under weak light (e.g. indoor with daylight)
    - Connects up to maximum 4 devices in the same time (depending on loading)
    - LED Power Indicator
    - Supports HDD upto 500G
    It’s not even that pricey, you can pick one up on USBfever for just $21.99!
    ("Do Not Pm Me Or Email For Support" For Mobile Stuff, Post your question/problem on the forum so that someone else who's having the same issue can benefit from the solution.)
    Wanna Introduce Yourself?! Click HERE
    Need to flash a rom?
    stlouisfinest68 has a great video tutorial on how to do it, click HERE
    Forum Rules: --> HERE
    Join A Group:--> HERE
    Learn To Get Around The Forum:--> HERE
  • rich7781
    • Jan 10
    • 1817
    • Tilt
    Re: Solar Powered Charging Solution
    hmm im a have to try this shit....
    • elboriyorker
      OG Member
      • Nov 08
      • 9328
      • Metro
      loll.that's cool when you're camping hahahahah i can see myself at a camp and on the net.
      SPJ Bulletin @
      www.smartphonejunkie.org
      • pete777
        • Sep 25
        • 303
        • blackberry curve
        • verizon
        While I don't see myself going camping soon, I do see a tropical depression looking thing south of the gulf. Hopefully won't need it, but it would be great to have, just in case!
          mmmmm i may hav eto pick one of these up or see if i can get a beta opportunity with the company and test the app :) ill keep you all informed.
